Pro Craft Electric Solderer
#1
Hello everyone,
I am thinking of buying a pro craft electric soldering machine but
want to know what to expect from it or whether or not to buy it.
I have some questions for whoever has used one of these.
Links to info on the pro craft soldering machine are below for
clarification purposes.
http://tinyurl.com/ybvjgnf
Instructions
http://tinyurl.com/y9ztldp
So, here are my questions:
#1 How does it work with relatively long solder seams? Say up to
1.5 inches long?
#2 How much does it heat up the surrounding metal? Can I solder a
part fairly near a gem without removing the gem? Approximately how
many MM away would be fairly safe?
#3 Does this avoid oxidizing most of the piece? It would seem likely
to only oxidize a small area around the solder joint, is this true?
#4 Do the tips wear out? Do they or any other part need replacing
with any frequency?
#5 How small an area will it fit into? Would soldering to assemble a
small basket head be a problem?
#6 Does it work better with big solder areas or small? Does it do
both well?
I know you are all busy but I would REALLY appreciate feedback on
this machine.
Thanks!
John Dyer
www.johndyergems.com
#2
1.5 inches long?
Not well. You’re soldering the metal that gets hot, which is just in
the area where the electrodes are in contact. These things can be
used for minor solder jobs, sizing seams on ladies rings or lighter
gents. Occasionally I’ve seen them do basic retipping work, or
various other smaller area joints. Long seams are almost impossible,
at least from what I recall. But the last time I bothered with trying
to get one of these dinosours to work was over 30 years ago…
No one given answer here. They heat us surronding metal somewhat
less than a torch, but the heating is slow enough that surrounding
metal does indeed get hot. How hot and how far depends on how heavy
the metal is, and what type of metal. How close to a gem also depends
on what type of gem. These are not replacements for lasers or PUK’s
when it comes to working close to a gem, and unlike a torch, where
you can often use heat sinks to get around the thermal problems, heat
sinking with the electric machines is more limited due to needing
electrods in contact with the joint area.
likely to only oxidize a small area around the solder joint, is
this true?
Oxidation is the same as with a torch, depending on what gets hot.
Remember that a tiny torch flame may also heat only the area right at
a joint, yet the metal nearby also gets hot from thermal conduction
because you have to hold the heat there for long enough to flow the
solder. The electric machines don’t change these rules. There may be
less oxidation going on nearby with the electrics on some work, but
I’d say the difference is minor if your torch soldering technique is
good. And besides, if you’re properly preparing the metal with
appropriate fire coats before soldering, Oxidation of the metal
shouldn’t be a problem in the first place
with any frequency?
The tips need replacing occasionally. They’re not costly, so it’s
not a big issue.
a small basket head be a problem?
Relative. Not as small as a tiny tip on a torch can do. Assembling a
basket? That’s a bit complex for these machines. Whether you can do
it would depend on how small, and how it’s designed, and how good you
are with the machine. With skill and practice, you probably could do
it. Now, can you get a good clean repair on a tiny chain, or a hollow
rope chain, or some other tricky small work? I doubt it would be
easy, if you could manage it at all.
both well?
Mostly suited to modestly small spot soldering jobs. No good at all
for large areas.
this machine.
If you’re in any sort of situation where you can get a torch setup
instead, you’ll be much happier with a proper torch. There’s a reason
these electric machines are almost never seen on anyone’s bench any
more. They’re not costly, and are cheap to run, but are also pretty
limited. In fact, all the ones I’ve ever seen were on the benches not
of jewelers, but of watchmakers, who’d very occasionally need to do a
minir repair to a watch case or the like, and who found these more
convenient to have around than an actual torch. For actually making
jewelry or soldering on more than an occasional basis, I’d bet
you’ll not be so happy with the electric machine. They have their
place, and they can do good work. But they’re a good deal more
limited than a torch.
Peter Rowe
#3
Hi Peter,
Thanks for the feedback! The truth is that I already have a Smith
Little Torch, the electric solderer would be in addition to that in
the hopes of expanding my repertoire, feeding my tool addiction and
hopefully making some things easier.
Sounds like you don’t like them very well though.
Thanks for your opinion, any others would also be welcome!
John
#4
in the hopes of expanding my repertoire, feeding my tool addiction
and hopefully making some things easier.
There are a very few instances where the electric machine is an
improvement. Generally they are ones where the ability to solder
without having the flame extend away from the working area, or
needing to approach it, are an advantage. it can minimize heat damage
to areas adjacent to the work area which are hard to avoid hitting
with the flame. But in general, these instances are rare. Usually
you’ll find getting a good solder joint is easier with the torch, at
least in my experience, which was rather limited with the machine.
The example that occurs to me as best typifying their best use is the
repair of some eyeglass frames where there are lacquer or other
finishes, and one needs to avoid even slight accidental heating of
areas any distance from the solder joint.
If you do decide to get one, you might want to check R.Allen Hardy’s
book on jewelry repair. At least I think that was the title. I’m
dredging that up from two decades ago. I recall a smallish size book
from some time period around or before ww2, if I recall. It, or
whatever that book was, had a whole chapter on using the electric
soldering machine.
But for my money, I’ll bet you’d be better served by adding to your
torch setup, a larger torch, like a Meco midget. Use the same fuel
gasses and regulators, just add Y connectors to run the extra torch.
It’s a torch with a larger capacity, so good for bigger items than
the little torch will manage.
That’s just my opinion, though. I’m sure some people like the
electric machine, or they wouldn’t still make the things. I’m just
not one of them.
Peter
