Dear Ivan
I know there's been posts about this. I've read that heat treating
will help. Time and temp are unclear. I've seen from 200-500f and
from twenty minutes to a few hours.
If I initially explain a little about how Argentium Silver works,
this should help you know what is happening in the alloy when
processes such as heat-treatment are applied.
Argentium Silver contains a small quantity of germanium, this
imparts improved properties to the alloy including firescale
elimination and tarnish resistance. The reason for these properties
is that when the Argentium is heated in air e.g. with a torch,
germanium oxide forms on the surface, this is a transparent oxide
which acts as a protective layer. Interestingly, tests have shown
that the germanium will also migrate to the surface naturally at room
temperature and will therefore replenish itself at any points of
wear. Heat treatments e.g. for precipitation hardening, will also
help to enhance the formation of germanium oxide on the surface.
Stern-Leach (the US manufacturer of Argentium Silver) now also take
steps to develop a protective surface oxide, as part of their
Argentium Silver manufacturing process. Please find below the
procedures for precipitation/heat-hardening:-
QUENCHING
The following precipitation hardening method will achieve a hardness
of approximately 120HV/DPH:-
Heat the alloy to a pale red annealing temperature, wait until
any visible red heat has disappeared and water quench. If using a
furnace, the recommended temperature is 1050F/565C.
Heat the alloy in a furnace/oven at 580F/300C for approximately
45-60 minutes and then air-cool to room temperature.
AIR-COOLING
Argentium Silver will also harden after a slow air-cool. The
following method will achieve a hardness of approximately 110HV/DPH:-
After annealing or soldering, allow the alloy to air-cool to room
temperature.
NB:
Lower temperatures can be used for Step 2 (minimum temperature of
220C / 365F) with a corresponding increase in time, e.g. samples
would need to be heat treated for approximately 2 hours at 220C /
365F.
Ovens/furnaces and supports should be preheated to the required
temperatures before commencing the heat treatment for the specified
times. A slight discolouration may occur during the hardening cycle,
this can be easily removed with a weak pickle.
Argentium Sterling shows a paler colour when annealed/soldered, it
is therefore recommended to carry out heating processes in a shaded
area, to prevent overheating.
As for degreasing after polishing, the dishwashing detergent Joy is
cheap, ph neutral and is used by several jewellers on their Argentium
Silver, just a few squirts into an ultrasonic degreasing tank with
tap water should do the trick at about 55C / 130F.
You should find that minimal cleaning is required, however if the
alloy does yellow slightly with time then washing with soap (e.g.
Joy) and water or a wipe with a Silver Cloth (the Goddard’s Longterm
and Tiffany Silver cloths can be recommended), will give both the
benefits of cloth and the tarnish resistant properties of Argentium
Silver. The cloth also helps to protect the surface against finger
marks and everyday dirt and grime.
You say that you use brass and copper in combination with Argentium
Silver. It could be that some “smearing” of the base metals on to
the Argentium occurs during polishing and this may cause the
decolouration you refer to.
For other people’s working experiences with Argentium Silver, you can
read Cynthia Eid’s technical paper, which can be found at
cynthiaeid.com and may I also recommend for you to take a look at
Trevor F’s blog at touchmetal.com - there is some very useful
on his site.
Regards
Peter
Peter Johns
Technical Director
Argentium Silver Co. Ltd
