I’m looking to purchase a tool stand for my GRS power hone. I see a lot of inexpensive ones on eBay. I have not purchased one because I am afraid they are low quality. Does anyone have any experience with these and what do you think of them?
Can you do me a favor and post some of the stands that you’re considering? I’m not sure what your thinking about.
I’ve got an old GRS powerhone and an old GRS dual angle tool fixture. It was expensive when I bought it 20+ years ago. Now it’s super expensive. I understand why you want to see if there’s a less expensive solution.
Thanks!
Jeff
Why don’t you build one out of wood. You can get to the exact height that you need. I have built them for my anvil, engravers vise and lapidary saws. You can see them on the Shop Shots page of my website…Rob
Ah, yes it did. This is what I’m seeing on eBay. It looks good, but I don’t want to waste the money on something that will break or not be accurate. I have experience with one made by GRS. It is very accurate with the angles. A real precision piece. That’s what I’m looking for.
Rob,
I’m completely impressed with your shop! Extensive and so clean!
The thing is, I’m pretty sure I cannot build something this accurate.
Thanks.
Hi,
oh, now i see what you are looking for…i thought you meant a freestanding floor stand for the power hone unit ![]()
as long as the fittings are all nice and tight…stable…lockable…and the grs quick change collets fit…and the angle fixture has a nagnetic base to stablize it…
julie
I agree with Julie, this looks well made. But whenever you buy anything without actually seeing it, you need to verify what the return policy is before purchasing. Most jewelry tool companies have a no questions asked 30 day return policy. Hopefully you get the same thing through eBay.
What’s the price? Is it way less than GRS?
Thanks!!
Jeff
They run between $105 and $115.
I guess that I misunderstood what you meant by a stand. Have you looked at Steve Lindsay’s sharpening system. Easy to use and less expensive. Plus, it doesn’t need a stand…Rob
We were actually gifted one of these GRS knockoff indexers, and in my opinion they aren’t worth the hassle. Not sure if the one you posted is the exact same brand, but it sounds like the price is similar, and it looks the same.
We had to modify the quick-change holder just to accept the GRS collets, and the angle markings on it are…let’s just say less than accurate. For example, when trying to make a 90* graver, one side would end up around 30*, and the other somewhere around 46*.
I know the GRS one is expensive, but if you’re really needing a way to quickly and accurately sharpen your gravers, then it might just be worth saving up for.
Saved. Im still struggling with graver sharpening.
Well, I broke down and bought a cheap one. We’ll see what happens.
Hi,
keep us posted in how it works out. what grit discs fid i come with? did it come with a ceramic disc and diamond spray?
check out the arbor hole size…
julie
I just bought the cheap tool holder. The thing that holds the graver.
Hi,
oh, right! sorry! you did say that earlier!
let us know how it goes! if you have the graver collets, it makes it easier to be repeatable.
julie
Well, it did not go well. It looks nice. It looks sturdy, but the collets won’t fit into the Holder. So I can not try it out to test the accuracy.
I have already asked for a refund, but they’ve started the bargaining. Offered me a $10 refund and suggested I give it to somebody as a gift. I have been here before!
