Hi all - this is a bit of a convaluted question because I don’t know
the name of the bead I’m looking for but I’m hopeful that one of you
beaders out there will know what I mean.
I’m looking for a supplier for the psuedo cone shaped glass or stone
bead that is often used as the finishing bead on Power Bead
Bracelets.
If any one out there knows where I can find them or what that
finishing bead is called and could share it with me I’d deeply
appreciate it.
I could’ve sworn Fire Mountain carried them, but now I only see the
finished bracelets in their catalogs.
Thanks in advance for all your help
Sydney
aka Skabeads
I'm looking for a supplier for the psuedo cone shaped glass or
stone bead that is often used as the finishing bead on Power Bead
Bracelets.
It’s called a “finial” or “tassel bead”. Rings-N-Things carries them
in several They also have the 3-hole beads needed to finish
the power beads just above the finial bead. You can see both at
http://www.rings-things.com/Catalog_Pages/123.htm (not affiliated, I
just like their stuff!)
–Kathy Johnson
Feathered Gems Jewelry
Hi, I don’t remember the name offhand (and don’t have the catalogue
with me), but I know Rio Grande carry them. www.riogrande.com - you
need to order the catalogue first if you aren’t familiar with them…
Hope this helps,
Claudelle in freezing Montreal Canada.
