Hi there! First post on the forum…
I have a client that wants a 2 tone ring - platinum inside and 18k yellow on the outside. Here is how I think I should make it:
Make the outside band a bit snug and then sand until a perfect fit, then solder the seam with an easy yellow gold (or white gold) solder.
Anything I should look out for, or anyone who has done this before? I can also steer the client towards white gold on the inside if it’s going to be a soldering nightmare!
Thank you in advance!!
Carolyn
