I told her I’d put her questions up on the Orchid:
I’ve only used the solution 3 times (about 30 pieces of jewelry). The
first two times, it plated beautifully and the last, I’m getting a
thin dull color. It does plate but after tumbling, looks more like
14k than the 24. how long should this solution last? I’m using it on
20g wire (handmade chain approx. 20" long) with a medium sized bezel.
It’s not like this jewelry is big or anything! Sounds to me like the
solution is just bad but I’d like to hear what they think.
Thanks for your help!
Hmmmm…It sounds like you are doing everything right. Try
lowering your temp to about 103 and see if there is any improvement.
If you are still getting less than satisfactory results, then I’d
return the solution and try another.
I’m not sure about the 24k solution but I have found that rhodium
plating solution becomes contaminated easily in a workshop
enviroment. I was advised to get a carbon filter, the type you use
in a fishtank, available from pet shops. What you do is pour the
solution through the filter then sterilise all of your beakers and
anodes etc. Everything must be thoroughly cleaned to decontaminate.
hope this works.
