Daniel, Mineral watch crystals should work for this. About .5mm -
.75mm thick as I recall and not very expensive. If you want other
than a stock round shape a watch repair shop will cut them in fancy
shapes.
Jeff Demand
http://www.aztec-net.com/~jdemand
Daniel- Have you tried Tri-Bro Tool C., Inc in Cranston, RI? They
have a fair locket selection and they offer in brass, copper,
sterling, and gold fill. I’m not sure what is available in which
metals but they are a great old company with lots of selection. good
luck
kate
Hi David, The best source for custom cut glass is a stained glass
dealer or artisan. They have all sorts of little shapes to etch and
fit into their work. If the artist doesn’t have it on hand, he/she
should have the expertise and tools to cut what you need easily. This
could turn into a good barter opportunity which most
artists enjoy. Patty Lux
where I might find cheap lockets or does anyone know a source
for glass that can be used in lockets? Thanks in advance.
G’day; three suggestions;
in lockets passed down from mother and grandmother which my wife
has, they both had pieces of what used to be celluloid inserted over
the tiny photos, but I removed that, replacing it with cellulose
acetate discs. That was 30 years ago, and they are still OK.
I have cut thin microscope slides by scratching a line with a
carbide scriber then snapping, finally grinding it circular on a
spinning medium fine lapidary stone.
I have used microscope slide cover slips for similar purposes, but
these are extremely fragile. Cheers, –
Parts for lockets
Why wouldn’t a thin dome of clear quartz work in place of glass? This
would make it more related to a jewelry product.
Larry
This may be an off-the-wall suggestion for the glass, but what about
using the slides for viewing specimens under a microscope? I don’t
know how thick they are, but they might work, and you could probably
shape them on a Genie. I assume that a store like “Mr. Science” or
similar would sell them.
Dianne Karg
Toronto, Ontario
www.wrapturewirejewellery.on.ca
