Hello again,
Well, I’m happy to say that I just found out that did end up getting
one of the grants offered this year by my local guild, although it’s
only for $200 (I was hoping for the highest one, the $500, of
course!). Still, that’s nothing to sneeze at & it will certainly
help out as I get my kiln & all the related stuff to go with it. I’m
very excited to get going will all of this, of course, so now it’s
coming down to the final selection. Basically, it’s between the
Paragon SC-2 or SC-3, and then the options are a bead door and a
peep window.
I think, since I only got the $200 grant, I’m not going to spend the
extra $120 for the 8" (inside) high SC-3, I think the 6" high SC-2
will be sufficient. I hope to do lampworking eventually, so I’m
planning to spring for the bead door. The remaining question, then
(unless I change my mind again on the other things!) is the window.
First of all, I should say that I want to be able to use this kiln
for pretty much everything for which it’s potentially useful-
enamelling, PMC, fused glass, lampworking. Yes, I can never do enough
different things! The only one of those I haven’t ever done is
lampworking, but since I love glass, I’m sure I’d like it. It’s a
WHOLE lotta stuff, though, lots of new tools & equipment, so it may
be a while.
The other things are ones I’m more familiar with (relatively
speaking), though, and do plan to do very soon. Particularly because
of the enamelling, I like the idea of the peep window in the kiln, I
don’t know that it’s too big of a deal for anything else. I read on
one of the supply sites, though (and I’m curious why no other sites I
looked at mention this) that the window is only good for up to 1700
degrees. I’m assuming that means that higher than that risks the
window breaking, not that it’s just not useful above 1700. So, with
my plans for all of these different kiln uses, does that temperature
limit me in any real way?
When I learned glass fusing, we only took the kiln up to 1500. It’s
been a few years since I’ve done enamelling, so I kind of forget (and
it was in the land of Celcius, anyway), but in looking at the books I
have it seems that for small pieces, 1500 is also a likely temp, with
only large pieces needing something like 1800 or higher (although,
I’m not sure what “large” means in this case). The only place I’ve
seen even a potential problem is if I decide to use PMC Gold, it
requires a temp above even 1800, let alone 1700. I don’t know that
I’ll use that, but I don’t like to restrict myself. Among the uses I
mentioned - glass fusing, enamelling, PMC and lampworking - am I
going to find a need to go above 1700? And I guess another question
is, is this restriction really the case? Any other insight to be
shared?
Thanks so much, you guys are a great source of ![]()
Lisa
Designs by Lisa Gallagher
www.designsbylisag.com
