Can anyone suggest the necessary tools / equipment to do palladium
plating on sterling silver?
Thanks,
Craig
Thanks,
Craig
Craig, this might help as well. Palladium Plating Check List
Plating Parameter Verification
*Note: Proper rinsing will help protect the expensive plating
solution
Andy The Tool Guy Kroungold
Phone 800-877-7777 ext 4194
Can you use this Palladium to plate white gold instead of rhodium?
This has got to be much cheaper. Wouldn’t this be a dream come true.
Thanks Johneric
On polygon there was a discussion on the palladium plating. Its not
as white (more grey) than rhodium
It WILL PLATE over silver.
This one jeweler said he’s use Palladium on repairs, higher end
stuff he’d plate with Palladium and then plate over it with Rhodium
but half the time.
David Geller
www.JewelerProfit.com
Searching the archives, I found a discussion “Rhodium plating
silver”
Rhodium plating will and should last for a few years.The problem is that their is a difference in the quality of Rhodium plating from plater to plater.there are also sinthetic rhodiums that do not last more than a few weeks and then there is paladium plating which requires 4 times more plating than good rhodium to be equivalent.Many who use paladium instead of Rhodium do not realise this.
And while these statements don’t contradict each other, they don’t
draw the same picture, neither. I agree that plating is an art in
itself, and there are good platers and there are bad platers, and
there are jewellers who buy a rectifier and a bath.
There is stressed jewelry, mostly rings and probably bracelets,
where the coating takes more physical stress than, say, earrings.
So in my layman thinking I’d say: Ok, I’d lightly paladium-plate my
earrings and neckware myself, double on bracelets and find a real
good rhodium plater for my rings.
Right? Wrong? Irrelevant?
Thanks,
Andreas
P.S.: Who are the real good platers in France or Europe. Reply
off-list if you wish. Thanks!
contradicting" does not make sense. So here is the first part which
references a comment from David Geller:
This one jeweler said he's use Palladium on repairs, higher end stuff he'd plate with Palladium and then plate over it with Rhodium but half the time.
Again, what seems interesting is replacing rhodium with palladium,
but only if the results are comparable. I’d love to hear your
thoughts and experiences.
Thanks,
Andreas
It will plate on white gold as well silver without an under coat…
the important things are the temperature at 105 and the ph at 8.5…
