Noel,
I have not done oven soldering by any means, nor have I seen or
heard of the toaster oven technique, but I think I can answer your
question about the toaster oven.
The 450 degree temperature indicated in the oven is essentially the
air temperature in the oven but not necessarily the temperature of
individual objects within the oven - the heating element itself
being the best example of that as it glows red hot. 450 air
temperature is plenty hot for most cooking operations. The
thermocouple (heat sensor) which measures the temp is not in contact
with nor exposed to direct infra-red radiation from the heating
element. It responds to the ambient air temperature. The air is
constantly moving in the oven, convecting, and is losing heat
through the walls and door etc so it tends to stabilize at some
level consistent with a balance between input of calories from the
heating element and loss of calories to the surroundings. I should
think that a metallic object under the toaster or broiler element
could very easily be raised to soldering temperatures far in excess
of the air temp in the oven. The air in the oven itself is a
relatively poor conductor of heat ( trapped air pockets are the
essential element in most insulating materials) and so the
temperature of the soldered object in the oven can be driven up
quite high and not carried off quickly by the surrounding air in the
oven.
Baking operations in a toaster oven may, depending on design, be
governed by a thermocouple which turns off the heat when a pre-set
temp is reached and turns it back on when the temp falls below that
level. However, toasting operations, when done as intended by the
mfr, that is, to a slice of bread rather than metalwork, are
typically governed by a timer rather than by a temperature sensor.
The element turns off after a pre-determined time passes rather than
at a pre-set temperature, thus determining how dark your toast will
get. If the timer is de-activated or over-ridden, perhaps simply by
manually turning it back on instantly when the little bell goes
ding, I imagine you could get the temp quite high.
I know this is fairly primitive but if you are not doing high volume
production I bet a toaster oven would be a good way to do some
one-off oven soldering without the huge expense of one of those
automated conveyor belt devices - and you could heat up your lunch
too!
Marty in Victoria - where I hope to get the heat installed in my
basement shop pretty damned soon!
