I got sick of using my crinkly old ring size chart and having to hand
calculate from it, so I wrote an online ring blank length calculator
(in Javascript so you can see the code if you like). I based the
calculator on the H&S chart I have and what I was taught for wider
bands (e.g. for bands wider than 4mm you take the width subtract 4
and multiply by .5 then add that to the length). The calculator is
here:
Just want to say thanks to Mike for posting this link and being kind
enough to share your very handy calculator! Used it today to make a
ring, just had to convert UK size to US and mm to gauge size
first… : )
I am getting a 404 error and when I click on tools/apps it wants to download a file that I did not ask for. .gz ending. Maybe check your website to make sure you were not hacked?
If you download the offline version, when you decompress it it will not have a file extension. Some browsers will display the code in that case. Just rename it to something sensible and add an .htm or .html extension.
