Now that we are getting good results casting Argentium, we also need
to get on top of fabricating with it. I’ve been experimenting, trying
things out so I can educate the other goldsmiths in the differences.
I know AS conducts heat more like gold (does not conduct heat as
well) and fuses pretty readily. We’re using My T Flux, and that seems
fine. I know it is very hot short, and should not be quenched right
away.
I got some Argentium medium solder. But I wonder-- do you use AS
solders just for the match, or is there some problem if you use
ordinary sterling solders?
What else do I need to know/familiarize myself (and the other
goldsmiths) with?
Thanks!!
Noel
