Perhaps some of you missed There is way to etch Gold with hydrazine -
I Have used this process when needed (rarely) over years and years
since My printmaking days in an MFA programme.
however hydrazine should never be opened, possesed, or worse, used
in a small scale jewelers studio _ unless you have a full blown
laboratory that is licensed in your back yard.
if i were in the poster’s town i would be errant not to report that
the person is risking the lives of everyone in his studio and within
100 ( immediate and more with a strong wind) yards of the gases
generated when adding metal to it!
it must be licensed for use. and dispoed of very specifically…
do not try obtainng it or using it :the reultant gas kills with the
swiftness of zyklon b…and death is horrible painful and prolonged
and will occur if you decide to try this.period!!!
of all the posts that get snipped by the moderator(s) any that
recommend or suggest hydrazine as a viable alternative to the safe
and tried and tested process i have provided below is simply mind
boggling.
To etch gold one has to use a traditional photo process:
Clean your metal in acetone, MEK (methyl Ethyl Ketone) or lacquer
thinner In a darkroom working under a yellow lamp ( not red), Prop
your metal Plate up against the container wall( glass or stainles
only),apply Kodak brand KPR resist to plate by brushing it on or
dipping it ( if Its a small piece)
Let it dry in the dark for two days ( about 48 hours at any rate)
Contact print film sheet under a pane of glass and expose it to
Sunlight, a high powered sodium halide light, sun lamp, or bank of
4, #1floodlights- even a head of 24 led’s will do the job! If you are
lucky enough to have access to an arc lamp 5 minutes is Required for
Perfect results, in sunlight, figure you will need intense sun at
About 4 hours exposure ( say between 11 am and 3pm EST)
Develop the plate of metal in KOP ( a kodak product) for 3-4 minutes
Lightly agitating it as for film development( the solution is washed
Over the metal by lifting an edge of the container ( a 2 1/2" sided
Steam table pan of stainless steel or glass pyrex type baking dish
Works great!) And lowering it repeatedly for the specified amount of
Time ( you can go too long in which case your material will begin to
Lose the detail you intended as the resist breaks down)- do not use
plastic for the kop solution it will eat it rapidly
Wash the metal under running warm water and the image will appear. (
i Usually put a generous amount of sodium bicarbonate in the washout
Sink ( about a quarter of an inch thick ) to neutralize the solution
Before it goes into the grey water that i use for gardening, etc-
you May want to do the same before it hits the city sewage system- it
is Very corrosive stuff and not healthy for any water system
untreated)
Etch the image in a solution of 1 part nitric acid, and 3 parts
Hydrochloric acid. The photo image will appear immediately when
etched In this mordant.
It is usefull to have a large turkey, crow, raven or other feather
on Hand to brush away any bubbles that seem to cling longer than
necesary From the areas that have no resist on them.
Use any of the solvents mentoned above to remove the reisit when you
Have achieved the desired depth of etch, then wash well and finalize
With a neutralizing rinse of about a pint of water to 3-4
tablespoons Of sodium bicarbonate ( more is actually better in this
case, but a Paste is overkill!)…
If you have questions feel free to email me off list Dr.R,E,Rourke
