Ok guys, here’s a weird question for ya:
Does anyone know where to get the heat sensitive color changing
enamel used to make mood rings?
I know that it can be mixed to respond to different heat ranges, as
I’ve seen swirled rings that have areas that don’t change color at
the same rate.
I know that the heat sensitivity goes all the way thru, as I’ve seen
a broken piece once.
Any suppliers known to orchidland?
LJ
You can buy them as beads. And you can get the plastic version at
Elaine
