If you are looking for ready-laminated silver-and-copper or
silver-and- brass (28 layers really compressed!), it is sold by
Reactive Metals (address in Metalsmith Magazine). It doesn’t come
in big sheets, but it goes pretty far when you mill it.
Reactive Metals has a web site - http://www.reactivemetals.com/
What a lot of interesting stuff! They have miniature taps and
dies to make your own tiny screws and threaded holes - sounds like
a neat little toy.
Jill
@jandr
http://members.tripod.com/~jilk
Queens, New York City
Hello All, I decided to try my hand at making mokume gane following
the diffusion method. To start, I want to work with copper, nickel
silver and Sterling. A couple of things are unclear to me, so I would
like to ask a couple of questions.
The laminant stack has to be secured in steel clamping plates
with bolts. Does anyone know where I can purchase such clamps? About
which measurements are we talking here? I do not want to melt the
clamp. -
Is it a good idea to preheat the clamps several times as to build
up a layer of oxidation which will subsequently prevent the
possibility of the lamination fusing to the plates? -
I do not have a forge or a firebrick oven. Is it possible and is
it a good idea to use my burn out oven for it? I heard that a burn
out oven can indeed be used, on the condition that the laminant stack
is put on charcoal in an sturdy box made of steel. Could someone
please elaborate on this? How much charcoal do I need to use? How
sturdy does the box need to be? Is there no danger of damaging my
oven? Is the little hole in the oven sufficient to get all the fumes
(carbon monoxide, carbon dioxide!) out of the way? -
Once the laminant has been shimmering for a couple of minutes,
the construction has to be freed from the clamp while it is still red
hot. What is the best way to accomplish this? Isn’t this a rather
dangerous operation? Thank you for reading. Any help will be greatly
appreciated. With best regards, Will
Will -
I will try to answer your questions as they come up. You wrote:
Hello All, I decided to try my hand at making mokume gane following the diffusion method. To start, I want to work with copper, nickel silver and Sterling. A couple of things are unclear to me, so I would like to ask a couple of questions.
If I may make a suggestion…get rid of the nickel silver. My first
billets were copper brass and nickel silver and they are very hard to
roll. Later, I did copper and sterling and it rolls like
butter…comparatively.
1) The laminant stack has to be secured in steel clamping plates with bolts. Does anyone know where I can purchase such clamps? About which measurements are we talking here? I do not want to melt the clamp.
I had mine made at a local machine shop. The two plates are
10cmX10cmX1.6cm (thick) with 13mm diameter holes for the bolts
drilled approximately 5mm from the edges at the corners of the plate.
Everything is, I believe, tool steel to withstand the heat. The
bolts and nuts must be the same material
2) Is it a good idea to preheat the clamps several times as to build up a layer of oxidation which will subsequently prevent the possibility of the lamination fusing to the plates?
I didn’t. I used yellow ochre to paint the inside faces of the
plates to prevent fusing.
3) I do not have a forge or a firebrick oven. Is it possible and is it a good idea to use my burn out oven for it? I heard that a burn out oven can indeed be used, on the condition that the laminant stack is put on charcoal in an sturdy box made of steel. Could someone please elaborate on this? How much charcoal do I need to use? How sturdy does the box need to be? Is there no danger of damaging my oven? Is the little hole in the oven sufficient to get all the fumes (carbon monoxide, carbon dioxide!) out of the way?
I use a burnout oven with a pyrometer for Mokume (but I don’t use it
for burnout anymore). I wrap the whole stack (torque plates and all
with tool steel and pile in aquarium charcoal. I follow the
instructions that James Binnion has kindly provided at
http://www.mokumegane.com/Workshop/Mokume_Workshop.html
4) Once the laminant has been shimmering for a couple of minutes, the construction has to be freed from the clamp while it is still red hot. What is the best way to accomplish this? Isn't this a rather dangerous operation? Thank you for reading. Any help will be greatly appreciated. With best regards, Will
If you put the stack inside a tool steel bag, you will not be able
to see any shimmering in the stack. So, I simply heat sink for 8-10
hours, turn off the kiln, let it cool, disassemble the plates and
then heat and forge the billet.
I have had good luck with this in several different mokumes. I
have not killed myself yet, but I do set the kiln in a
well-ventilated area.
I have seen the process done in a forge and there are several
differences: there is no need to create a reducing atmosphere (thus
no charcoal & tool wrap) because the forge itself provides the
apropriate environment. In the forge, you can see the stack “sweat”
so you know when to remove the stack and there is less time involved.
Once removed, the bolts are cut off, the plates opened, and the
stack forged.
I hope this is a help. I would be happy to answer additional
questions if I can. I wish you persistance and success. Mokume is
really beautiful and fun. I am very grateful to James Binnion and
Orchid for helping me to get it right.
Debby Hoffmaster
