Masters, Pros, Amateurs, and Hobbies, your attention please!! If you
are looking for a wax gun may I take this opportunity to suggest the
this homemade wax gun! Allow me to expound it’s features and advise
as to its options to include a little of the research that surrounds
the superb tool…
Homemade wax gun with a little ‘sweat equity’:Total cost: $16.97
Prior to providing parts, cost, wiring consider the
following features available which are not currently available with
other guns.
ON/OFF Switch
The currently model (below) is equipped with the 'click on/off’
switch. Rotation of this switch allows more heat to be the gun. An
optional switch, the ‘Push on/off’ switch can be provided with an
additional feature of a signal light when the gun is on. This
feature will cost an additional $2.00 depending on location.
Gun size and features
Several guns are available; Large gun with interchangeable nozzles.
Priced at about $12.00. low Heat gun. price/size the same as the gun
suggested… not recommended (… regulating the heat anyway).
For the bench jeweler who insist that his/her bench tools, equipment
maintain that certain DECORATOR, or who has everything, SDJ offers
the following models;
Sport Model.The sports model comes with a Cobalt Blue base, White top
and switch, Gray electorial cord with white gun… Model is
generality available in most hardware stores.
Decorator Model. The Decorator model comes with black base, top,
White switch, and black electorial cord with HOT Pink gun … most
stores.
Macho Model. The Macho Model comes with black base, Wood Grain top,
Cream switch, with Black electorial cord with black gun.
Part Cost
A two-gang, electrical outlet box. Metal/Plastic. $ 1.74
A Plastic/metal duplex outlet cover (to cover the two-gang outlet
box WHICH CONTAINS the dimmer switch, and duplex outlet). $0.42
A duplex outlet (get the grounded type). $0.81
A dimmer switch (Rated at 600 watts minimum). $ 3.54
A heavy duty extension cord (get one with a ground wire)… The
length should respect the location where the gun will sit relative
to the distance to the electrical outlet. $ 2.00
A solderless electrical wire connector(screw on). (got 15 in a box)
$ 1.99
Electrical tape (as required). $ 2.00
Wax Gun $ 3.97
Installation:
Be very careful doing electrical work. Insure all screws are
tightened, no wires are left exposed (ground wire possible exception)
and all dimmer wiring instructions are followed. Check your work
TWICE before connecting the finished device to an outlet. A wiring
error could result in destruction of the dimmer.
PLASTIC.Cut out CENTER, ‘Knockout’ at the bottom of the box. OR If
a plug, cut the plug loose at the bottom, bend up,DO NOT REMOVE OR
CUT LOOSE COMPLETELY if plug is to be used to hold the line wire in
place Some boxes are design to use the plug to hold the line in
place.
Insert the LINE CORD (larger than extension cord (about 14 gauge)
through the hole created in step 1. Press the plastic, tab cut loose
in step 1, back against the line cord (If your box had a tab)
Separate the wires in the line cord so there is aprox. 3 inches of
each wire, in its own latex sheath, available. Insure that none of
the conductors are exposed. The ground wire (green) may be exposed.
Strip each wire a little less than 1/2 inch until the bare wire is
exposed TWIST THE STRANDED WIRES OF EACH INDIVIDUAL WIRE TOGETHER.
Attach 1 DIMMER SWITCH wire to one of the LINE CORD wires(not the
small ground,usually green, wire) using the solderless wire
connector (screw on).
Attach the 2nd DIMMER SWITCH wire to the side screw, by the top
outlet with the short and narrow plug slot.
Attach the 2nd LINE CORD wire to the side screw by the bottom
outlet with the short or narrow plug slot(NOT THE GREEN COLORED
SCREW).
Attach the SMALL Ground, USUALLY GREEN, wire to the GREEN SCREW by
the SCREW SUGGESTED IN STEP 7 ABOVE.
Place both dimmer and outlet in the box and screw in place … DO
NOT TIGHTEN AT THIS TIME!!!.. JUST ‘SNUG’ THE SCREWS IN PLACE.
Place the Outlet Top on the outlet box and review for screw hole
alignment.
Adjust dimmer and outlet on outlet box until the outlet top and
dimmer AND outlet holes match THOSE OF the outlet box holes…
tighten dimmer and outlet screws.
Install outlet box top.
Install dimmer switch nob as required.
Testing
Ensure the dimmer switch is set to the OFF position.(PUSH ON/OFF
CAN BE TRICKY HERE). WARE YOUR SAFETY GLASSES!!! I know you have
them!!
Connect the device to an ELECTRICAL outlet.
Set the dimmer switch to the ON position.
Vary the dimmer control through its full range, full off to full
on and back.
Set the dimmer switch to OFF.
Connect a lamp containing an incandescent bulb to the device.
Verify the bulb is good and the lamp is turned on before connecting
it.
Set the dimmer switch ON.
on to full off while observing the lamp. The lamp should go from dim
or off to full brilliance to dim or full off.
If the lamp functions as expected, set the dimmer switch OFF,
disconnect the lamp and return it to its proper location. Your
voltage control works.
If the lamp doesn’t function as expected correct the problem.
