stories. Does anyone actually know of anyone that had a tank
explode, had physical or property damage due to acetylene or
propane tanks. . . . Richard Hart
Hi Richard; I’ll bite. Here’s a couple true stories.
case #1.
My father, a glassblower, was doing a little lampwork (benchtop
glass blowing using pyrex tubing and a large torch) in a room off the
back of his house. He has been doing this sort of work for over 30
years. The valve on the propane tank was defective (this happens
more often than you’d think). My father is in his 70’s, and his sense
of smell isn’t what it used to be. A small spark ignited the pool of
gas that had accumulated around the tank. He tried to smother the
flames with a coat lying nearby. When it appeared he had put out the
fire, he lifted the coat, and a huge fireball rolled up and across
the ceiling. He got some minor burns on his arms and face, but fled
the house as the entire roof burned off and the place was thoroughly
charred throughout.
case #2
Two years ago, about a quarter mile from my home, a family was
renting an old mobile home. They were rather poor, as were most of
my neighbors, and couldn’t afford to have the big propane tank
outside refilled. The father got the bright idea to try to hook up a
smaller 20 pound propane tank to keep the furnace running. There was
a leak, and the gas was ignited by the pilot from the furnace. The
family got out OK, except for the family cat, but the mobile home
burned completely to the ground.
My point is, you’re right, driving a car is statistically more
dangerous. But if we had as many people using propane tanks indoors
as we do people driving cars, I think you’d see the statistics
change. I wear a seat belt and shoulder harness when I drive and
keep checking my blind spot. When I use tanks and torches, I check
for leaks when I put on the regulators, chain the bottles to the
wall, shut off the regulators, back out the T-wrenches and drain the
lines when I’m done. I never run an acetyline tank completely out, I
store propane outdoors, and never in an enclosure. These are habits
I developed when the safety and property of others was at stake,
such as employers, co-workers, students. Now it’s mainly so my kids
will have a live, healthy father as long as I can be that for them.
Make safe working habits into a sort of “grounding ritual” and rather
than having people think you’re a sissy, they’ll think you are a
Zen-like master.
David L. Huffman
