I have a Meco midget but the flame fluctuates so much I use my
Smith all the time. I would like to use my Meco again as I found
them better for some types of projects. ... Anyway, I've cleaned,
repacked, and just about everything I could think of, including
having a welding company check it out. But the flame still changes
so much its really useless. Has anyone had this problem? Is there
a solution? Daniel "
Hi Daniel, Though I’m far from an expert at these things, having only
begun working with metals a few years ago, it sounds to me like
you’re experiencing the gaseous equivalent of the line-voltage
fluctuations that used to dim the bulbs at my old apartment. Since
you haven’t mentioned whether you’re using natural gas, propane or
acetylene, and haven’t said whether it’s coming from a tank or a
line (i.e. a gas main), I’m going to deduce that you’re using
natural gas, and that it’s coming to you from a city gas main. (I’m
arriving at this conclusion because, except in cases in which there
are kinks or other obstructions in the rubber hoses leading from
tanks, compressed gases in tanks tend to expel themselves in
relatively ordered, predictable fashions, while those coming from
shared gas mains are subject to other factors, including usage by
other customers, especially restaurants, laundromats and similar
high-volume users.) If I’m right in my assessment, there are only two
ways I can imagine to overcome your problems. The first is to make
sure that you’re using the right tips for your Meco torch. (They
have a set of vented-tip models, which resemble your Smith’s rosebud
tip, albeit much smaller, which are specifically designed for use
with natural gas, whereas the others are meant for propane, only.)
The second way would be to contact your local gas company and ask if
they offer a higher-volume line for commercial accounts, like yours.
I seem to remember that the plumber who came to assess my workshop’s
needs, last year, mentioned that natural gas is pressurized to
different levels in different locations, and that there were some
lines which were pressurized to 7-10 lbs/inch, and others, which
were only pressurized to about 2 lbs. In theory, if you were to
combine the wrong tip style, the lower pressure level and a relative
proximity to one or more variable volume users, you could easily
create a scenario in which your flame sizes would vary all across
the map. (I recall quite a few days like that, when I was in
school.) But change just one of those variables and I think you
should be able to improve things, if not remedy the situation,
entirely.
If you’re using the torch with a canned gas, could it be that you’re
either running low or dealing with a bad batch of gas? (While
filling in at a friend’s store, last year, I had similar experiences
using his Little Torch and a 14 oz. can of propane.) If that’s the
case, perhaps a different can’ll fix the problem? Again, I don’t
know enough to even speculate on this variation, but hope that
something I’ve said will prove helpful.
All my best,
Douglas Turet, GJ
Another Bright Idea! / Turet Design
P.O. Box 162
Arlington, MA 02476
Tel. (617) 325-5328
eFax (928) 222-0815
anotherbrightidea@hotmail.com
