I’ve been asked by a customer to make a piece of “body jewelry” for
him, and I need some guidance as to which metals I should be working
with, if I make it, at all. The piece he has in mind is something he
says he’s seen on several friends in the Indonesian community, and
from his description, it seems to be a slender tube with 0.05 ct
Diamonds at either end, which he intends to (and I quote:)
“permanently insert through the bridge of my nose, so that the skin
grows over everything but the Diamonds and the bezel that holds them
in”. Having never taken on anything like this before, I’m more than a
little nervous about it, and, frankly, scared as hell about the
ramifications of potential liability for whatever reactions his skin
might have to alloys.
Has anyone on the list ever tackled jobs like this, before and, if
so, which metal(s) did you use’ From the description I’ve been given,
it sounds like the way to go would be to use my water torch to fuse
(rather than solder) two nesting tubes of platinum or palladium
together, then tap screw threads into the outside of one and the
inside of the other – to make a miniature barrel clasp, or sorts –
then do a traditional tube setting of the stones into the ends, and
have hime hire someone else to do the insertion (like whoever’s done
the many, many others on his body). Can someone tell me if I’m on
the right track, here’ (please’)
A great many thanks,
Douglas Turet,
G.J.,Turet Design
P.O. Box 242
Avon, MA 02322-0242
(508) 586-5690
@doug
