Hello. Any recommendation on a manual compressor/pump that can be hooked up to this wax injector (and how to hook it up)? I only do one-off waxes and don’t mind manually pumping. Thanks!
How much pressure and flow do you need. There are lots of different air compressors around. You might even be able to use a small hand pump like those used to bleed a brake line. They typically can be both am air pressure and vacuum pump. Flow probably isn’t that important since you are are in a static state and not in need of air flowing at a minimum rate, just pressure. I am not a caster, but you probably need a non-lubricated source of air. Good luck…Rob
