Hi Terri,
Thanks for your comments. Since I posted I have done a trawl of the
web and, indeed, there only seems to be on glass micro
mosaics, however, a few years ago I had a beautiful antique pocket
watch in for restoration which had a micro mosaic panel on its back
cover done in semi-precious stones. Maybe it was just a one-off…
I have a feeling there is also a stone micro mosaic on a jewellery
piece in one of the local museums but it is possible it is just
weathered enamel.
Can you really direct me to filaments in the 1mm or less diameter size? To square a rod requires extra work, and I would think that would make them cost-prohibitive
I wasn’t thinking of rods of micro mosaic proportions off-the-shelf
, rather I was thinking of the 3 - 5 mm stock that ‘art glassblowers’
use which could be easily drawn down to the correct size using a
bench blowlamp.
Good luck with your project - I look forward to seeing pictures
Best Wishes,
Ian
Ian W. Wright
Sheffield UK
