I think shortcuts are okay once you've learned to do it the "hard" way - ya gotta earn ya stripes.
To go a bit farther - I object sometimes to the word “shortcut”, and
I think often people don’t understand what they are saying at all (I
don’t mean this case specifically). If someone teaches you to set
prongs with a graver and file, and somebody else uses a hart bur, is
that a shortcut? No, graver setting is old world, hart burs are
modern setting technique. Using precut settings is a shortcut and I
could go on about those… I hear so many people here talking about
sandpaper - I use it but not very much, and never carborundum. Use a
good file, it’s the “proper” way to work - files aren’t shortcuts,
sandpaper is a poor substitute and the long way around for shaping
metal. Nothing against sandpaper, but it’s cheap, files are quite
expensive, so that’s what schools teach.
The only thing that matters is the end result - the end result is
determined by what methods are used to get there. Meaning that if
you can set a round bezel in 1/2 hour, and I can set it in 30
seconds and they both look and act the same, I know what I’m doing
and you don’t - that’s not a shortcut, it’s skill, tooling and
working efficiently. This is why we have apprenticeships, formal or
not.
There are many, many examples that I’ve heard but don’t necessarily
remember exactly. “Bend it, 3 sandings, squeeze it, stand on your
head, eyeball it again…” Or just go “Thwack” with a hammer,
file it out and we are done. How does that formula for making a
bezel go? X+2y squared times the multiple of the tangent? I just
wrap that sucker around the stone, but who am I… Lot’s of stuff
that isn’t a shortcut, people were just taught a laborious process
to begin with, and then need to unlearn bad habits.
Just because somebody teaches you a recipe doesn’t mean that’s how
to cook. Jewelry isn’t made by 1) Pick up pliers 2) Squeeze joint 3)
Solder joint 4) Put in pickle. It’s made by understanding the
principles, of which there are many, and then applying those
principles daily. Just because a school taught you the routine above
doesn’t mean that’s how to work, it’s just the way to teach
something. “Let’s get that joint soldered and move on.” How you
accomplish that means little, almost all the time. If you take
actual shortcuts on that seam, you’ll have a bad seam - if you can
do the job properly, but without the baggage and three times faster
than most, then you get the gold star. If you sand and file and soak
and scrub and agonize for an hour over a seam, and I pick it up and
solder it together out of the box in 90 seconds, and they are
identical, then you are wasting your time. Work smarter.
