I have a used REY-VACU-CAST casting machine. I don’t have a manual
for it though so I’m not clear about a few things. Does anyone happen
to have a manual for this which they might be willing to copy for me,
or sell me? can someone give me guidance on changing the oil in the
compressor, how oftenit needs to be done, etc.
I will be glad to photocopy the manual for you. There isn’t much in
the manual, but it is good to have it. The vacuum pump oil should be
changed as often as possible. The pump has steel parts inside and
each use will condense water into the oil. To avoid rust and poor
performance, change oil as often as you can.
