Hi GarE;
First, let me say that those little gems are fantastic! I’d love to
own one myself. Right now, however, I’m saving up to upgrade from a
bicycle to a car… just in case I need one.
This is a perfect forum for you, not only because your project is
germaine to the interests of this forum, but because this forum
exists to address just such issues. And by the way, since you are
obviously an artist working in metal, you are most welcome to this
forum.
You are correct, there would be an issue with directly enameling on
the metals, at least with vitreous (fired glass) enamels. The melting
temperatures of those metals, if they are what I think, is too low
for most, and things like copper, that have higher melting
temperatures, will, becuase of their reactivity, limit your color
choices.
There are inexpensive colored resins, like the “Colores” line that
Rio Grande carries, but I’m not sure they are suitable for a quality
article, since they are basically a not too hard plastic. There are
new colored resins that cure with ultraviolet light that more closely
resemble fired enamels, and they are much harder. They are the same
that used in the dental field for bonding. They can be finished and
polished. They are a bit pricey, and the light to cure them is an
investment of around $1200 if I remember correctly.
Yes, you could fire inserts and epoxy them in place, or devise
mechanical means of attachment. That would allow all the
extraordinary range of fired enamels.
I’d like to throw out another idea for you. How about inlaying gem
materials? Jade, onyx, jasper and agate, there are lots of materials
that can be easily aquired in slabs, and most experienced and equiped
lapidary artists use this technique all the time on jewelry. I’d say,
forget the softer plastic resins, maybe consider the hard, light
cured ones for production runs, and experiment with creating unique
editions using a palate of gem materials, or a collaborative effort
with an accomplished artists working in vitreous enamels.
Welcome to Orchid! Expect many more compliments for your beautiful
work from those of us on the forum with an eye for the unique and
beautiful.
David L. Huffman
