OFFICE MEMO Liver of Sulfur Date: 10/24/96
Dave, M.G. and John,
Thanks for the replies.
As John described, the Liver of Sulfur is used for oxidizing/antiquing silver
and other metals. I use it with pretty good results, although I haven’t
worked with it enough to describe how to get a really even coloring. I
typically heat the piece I am oxidizing and heat the liver of sulfur mixture
then apply it with a brush where I want it (usually in recessed areas like
engraving) then buff off what I don’t want just leaving the detail
highlighted. Sometimes I have to apply multiple coats in order to get it to
the color I want. I am very interested in other alternatives.
John’s message was very insightful. I keep the liver of sulfur in its
original container it was shipped in, a white plastic Tupperware type
container. I don’t think it seals too well.
Below is part of an article I found in the tips from the jewelers bench which
describes a method for applying the liver of sulfur. See what you think…
Steve
excerpt - do a search on “liver” to locate the full article
- The finished piece may now be colored with liver of
sulfur and ammonia. My experience is that most control is
achieved in this case by using an alcohol lamp to heat the
object with. This provides more or less heat as one needs.
One begins by pouring some ammonia into a small container
(household clear ammonia is best) and then painting the
ammonia on. Keeping the metal surface moist the whole time is
important. A tiny amount of weak liver of sulfur solution is
introduced to the ammonia and this is painted on the same
way. The color begins to develop slowly, first oranges, reds
and so on. If it has gone too fast or is unsatisfactory one
can anneal, pickle and start over. It is also possible to
heat the double surface until the oxidation begins to
disappear and then plunge it in to liver of sulfur solution
which can produce a ‘solarized’ look to the areas around the
exposed silver. The pin shown in the post card dated 1984 is
an example of this. Exposed silver areas will turn black as
is usual with liver of sulfur. The surfaces could be waxed
slightly or otherwise sealed. I leave my surfaces unsealed.
There does not seem to be much of a problem with color
fading. One silver piece I have oxidized yellow/purple/red is
still unchanged after eight years without protection. This
could vary with the surrounding atmosphere. As a final touch
lines may be emphasized on a paper rolled finish by lightly
burnishing them.
