I have very good lighting over my bench but for very small, detailed work overhead light isn’t good enough.
I’ve been using a somewhat large goose-neck desk lamp with a CFL bulb to put light where it is really needed, but the lamp is large and gets in my way.
This is an exaggerated setup to make a point, but I found an LED lamp that does not run to 3 figure$ that can be positioned exactly where I need the light and it is still small enough to be out of my way:
I really need only one lamp, but this comes with two, and the extra light is not a problem. I found this on Amazon for $39.99.
The clamping base uses parallel jaws. It doesn’t open wide enough to fit the edge of my bench, which is 2 1/4" thick so I have it clamped to a bench pin. The clamp is made of what looks like brittle plastic so you don’t want to over-tighten it. Clamping it to a bench block might allow for more flexible positioning.
This solves my lighting problem nicely. Now if I can find flip-up 5X magnifiers to attach to my eyeglasses…
Neil A
