Is anyone out there leasing a laser welder? If so I would like to
make contact with a company willing to do the same for me. This
seems like the perfect option to buying such an expensive item.
Thanks,
David
dagronick@aol.com
Thanks,
David
dagronick@aol.com
Rio Grande currently works with several leaseing companies for the
LASER’s that we sell. You can give us a call at 1-800-545-6566 and I
can get you all the details on both the laser and the leasing
options.
Respectfully,
Phillip Scott G.G.
Technical Support & Sales
Rio Grande
1-800-545-6566 ext 13752
Is anyone out there leasing a laser welder? If so I would like to make contact with a company willing to do the same for me. This seems like the perfect option to buying such an expensive item.>>
Hi David,
We got our Laser Welder from B & D Sales Corporation in RI through a
leasing. They have several leasing options.
But other than just get a Laser, you should consider which brand
first. There are several “sexy” machines out there, some of them very
questionable regarding reliability and technical support.
The laser we got is Alpha laser, build in Germany with Syro
Lasertech technology. After an extensive research, we’ve decided for
this reliable production laser welder. The leasing plan turned it
possible, and their technical support is amazing.
If you want to check them out, here their contact info:
www.bdsales.com - phone: (401) 781-4810 - Patrick.
Good Luck
Christo
David,
I don’t lease a laser I own one. I own a Zahntech out of L.A. They
have a lease plan and I would highly recommend them. I believe they
make the best laser welder in the market. It has a larger welding
box so I can do silver pieces such as teapots and vases there is no
need to change filters and no expensive maintenance it has an
internal cooling system and an external optional cooling system they
both run on distilled water. It has beam shaping and the ability to
store preset welding parameters. I use it every day and love it. I
can weld any and I mean any type of metal. I use it to do all types
of repairs. I size rings with it every day I do costume jewelry
repair, gold, platinum, titanium, brass steel. I have not used my
torch except to anneal metals and melt in almost 2 years. They also
have a lease program.
Regards J Morley Goldsmith/Laserwelding
We work with a lease company… Sunbelt in TX
Andy " The Tool Guy" Kroungold
Tool Sales / Technical
Stuller Inc
Phone 800-877-7777 ext. 94194
Fax 337-262-7791
Hello, we are leasing a laser through a company called Sunbelt
Lessors Inc. They can be reached at 972-644-0612. I dealt with a Mr.
Spanier
Good Luck.
Dennis
