Mysteam dragon seems to be leaking from between the black plastic amd the metal bracket. If anyone can offer any insight as to a fix it would be greatly appreciated. Thank you.
Looks like it was exposed to freezing temps while the pump had water in it. It happened to mine too. I took it apart and flattened the flanges and reassembled. Still never primed properly again.
Probably the fix is to replace the pump.
Rick Copeland
Rocky Mountain Wonders
Thanks Rick,
The pump primes, and the steamer works as it should. Freezing is a slight possibility but my shop is temperature controlled year round. If i took it apart do you know what i might look for?
Call Hoffman New York. They are very helpful.
