I’ve been following this discussion for a bit here, unfortunately
there are definitions that are being used improperly to dictate what
is what…Here are some factoids to ponder.
Capillary action is present in both brazing and soldering. This
is purely a function of fitment and that the filler alloy be in a
molten (liquid) state. Capillary action is not a defining action that
determines soldering or brazing. It is purely a physical property of
a fluid moving along two closely, or not so closely, mated surfaces
and the surface tension that is created. It is the surface tension of
the liquid that causes the surface portion of that liquid to be
attracted to another surface. This is the definition of capillary
action, and why it works the way it does.
Brazing is what we are actually doing when we are soldering due
to the temperatures we are working with, this is by definition see
below
Brazing vs. Soldering - from a technical point of view is
strictly a function of the melting temperature of the alloy used to
join the two metal pieces. Brazing is dealing with filler alloys that
become liquid above 450* F, where soldering, on the other hand, uses
a filler alloy that becomes liquid below 450*F.
3.a.) Glancing at the Wiki…soldering is also described as using a
filler metal having a relatively low melting point…in our case,
do the solders used in the jewelry biz have a relatively low
melting point? Some could argue this point…after all, they melt
before our precious metals do…well, most of the time
anyway…This is possibly the reason why they are called hard
solders.
- Brazing vs. Welding - these are two entirely different processes.
Both involve heat, only one, welding, requires that the metals to be
joined be in a molten state for them to weld together.
4.a) In both Soldering and Brazing, the metals to be joined should
never become molten, it is the filler alloy in its liquid state and
its interaction with the surfaces that form the bond, that bond can
be physical or integrated into the metal surface.
4.b) With welding, the metals to be joined become liquid and pool
together, solidifying into a new solid.
4.c) Introducing a filler alloy while welding, OR the exact same
metal, to the pool of liquid metal simply increases the size, mass,
and in almost all cases, a structural element to the weld. Keep in
mind, not all welding processes uses filler materials.
Now we must talk semantics about all of this.
We make adornment; does it have to withstand tensile sheer above 50K
psi? No. It simply must withstand the abuse of the wearer. Is it
practical to weld everything we do? No. Some materials like silver
are extremely difficult to weld. Stainless and titanium are ideal
materials to weld. On the flip side, titanium is almost impossible to
solder or braze, and silver/gold alloys are very easily soldered
together. We all do what is practical, or what is within our reach of
resources.
Does the wearer actually give two cents how this stuff is created,
fabricated, repaired, or manipulated…I don’t think they care one
bit…they care if it looks pretty, is repaired/fabricated to
withstand daily wear, and most importantly makes them feel good about
their jewelry.
I think we are totally geeking on this subject. Personally, I am not
concerned what is happening on the atomic level of the bond. I just
care that that bond holds up over time. Will a laser help me do
things that are difficult/impossible to do by traditional
metalworking methods…absolutely. Am I less of a metal smith by using
the technology that is available to me, not in the least. We all
choose our paths in life, we all use the tools that are available to
us.
I also feel caution must be used when dictating simple things like
this. It is not James responsibility to correct, incorrect
but it is all of ours, and quite frankly that is what
this thread has become.
A welding fanatic…
P@
