Jurgen help
   If you have any additional questions..just call me or ask
here
thanks jurgen, you’ve made things easier. is there a heat sink
that will retain moisture longer than tissue paper and water to
protect our heat sensitive stones while sizing platinum rings
that won’t contaminate the platinum? to use in situations where
the gems are close (within 12mm proximity) to the brazing or
weld seam. many thanks in advance,
best regards,
geo fox
