Ray, Are there good jump ringer systems for heavy wire rings, like
12 and 10 guage jump rings that are 3/8 - 1/2 inch inner diameter?
Thanks, Jan
Jan, The standard and long (high production) Jump Ringers will cut
from 30 to 12 guage wire. Straight round mandrels up to 1/2" may be
wound on the standard winder. We also produce a set of mandrels in
finger sizes from 2 through 12. (Approx. 5/8" to 7/8"). The mandrels
above 1/2" have their ends turned down to fit the 1/2" capacity
chuck. These coils may also be cut without additional accessories.
Hope this helps. Ray
Jan, The standard and long (high production) Jump Ringers will cut from 30 to 12 guage wire.
I can easily cut 15ga (.0571), but for 14ga (.0641) I have to scoot
the blade to slightly off center.  I haven’t been able to get
consistent cuts on anything larger - I often have to finish the cut
with a hand saw.  What am I doing wrong?  I’d love to be able to
tackle 12ga!
-Spider (world’s biggest Jump Ringer fan)
Spider, Sounds like you either have a dull blade or the blade is not
centered in the guard/guide. The milled out section of the coil
holder’s top plate must also be facing downward contacting the coil
for maximum depth of cut. I suggest you also collapse the coil on a
wooden dowel like a Slinky. The dowel will support the coil during
the cutting operation. How are you feeling? Ray
