Hello Carol,
No, the Jump Ringer System requires the use of a flexible shaft
machine to drive the blade that cuts the coil into rings. The model
we recommend is the Foredom model S.
The reasons we designed it to operate with this machine and not the
Dremel is that while the Dremel will produce the necessary speed, it
lacks the power of the Foredom. Its motor would be stressed and
would burn out . The Foredom will give you a lifetime of service for
this use and many other uses while the Dremel will not. In addition
to this, the Foredom hand piece has an infinitely adjustable Jacobs
chuck while the Dremel uses collets. The Jacobs chuck allowed us to
design in a larger diameter shaft on the blade arbor for greater
strength. There are good reasons why professional jewelers use
Foredoms and not Dremels.
I hope this fully answers your question. My father taught me many
years ago:
CHEAP IS EXPENSIVE!
Ray Grossman
Ray Grossman Inc.
Manufacturers of the Jump Ringer System
