Hi Rick,
From reading all the posts, this is my somewhat thumb sucking opinion, for what it’s worth.
I don’t think that your investment is to blame because from my experience most general investments allow quite a wide margin of error before they fail badly.
To me your piece in the picture looks like there was either ash left in the plaster or the model material combined with the investment and subsequent burning out causes the mold surface to break away.
I say this because I have cast many organic pieces like insects and frogs and the like.
They generally produce ash after being burned out.
Sometimes the mucus skin combines with the investment and causes the surface to break away.
I normally blow the flask out with compressed air after burnout and before casting and this does help, but even so there still remains an ash residue that is picked up by the oncoming metal and it then deposited at the top of the organic model.
I mention this because the resultant cast has the exact same surface look as your cast does.
While this does not really affect he overall look of an organic piece, a smooth model like yours is obviously ruined.
I have read James Binnion’s paper and there he uses very complicated models that fit in perfectly with the printing genre.
So I ask this very respectfully.
Your model is very easy to make in metal.
To me it would seem much more simple to make a metal master, then use normal vulcanize/inject wax /sprue and cast method.
Unless of course, you are doing this as a resin casting learning process ( nothing wrong with that, for sure)
Anyway, my feeling is that ash is the root cause of your problem because only the top part of your model is bad, not the entire piece.
Disclaimer, I have never cast the resin you are using, so all of the above could be BS!
