Hello Orchid members!
So I have recently changed my casting set up and of course problems have arisen.
I now have a larger kiln where I am able to put over 14 flasks in, whereas before I was only able to burnout 7 flasks at a time.
I am now getting flashing on pieces which I have previously casted many times with my old setup. Not all flasks are showing this, but there are always a few flasks out of the 14 which have this problem.
I am using the same investment (Optima Prestige) and the same burnout programme and same casting temps. Everything is the same apart from the number of flasks fitting in my kiln.
Can this be the problem? Does the initial dry out need to be longer with this many flasks in the kiln? I can image there being much more moisture in the a small chamber for it to all dry up in the same amount of time over 1hour. Can’t find any info regarding this.
Should I have it ramp to 150c over 2,3 or 4hours?
Btw I let my flasks sit for 2-3hours before putting them in the kiln and I mix my investment all within the guidelines.
All the info out there regarding this saying “your flask temp is too high” or “your metal temp is too high”.I have tried lowering both, but I just don’t see it making a difference. As I mentioned 4 out of 14 flasks show a problem. I believe the cracks arise in the flasks prior to casting.
I am casting again next week, so any advice would be great…
Has anyone had similar problems?
Thanks
