I have a customer wanting a black wedding ring with a mystic topaz
stone. I know rhodium plating silver (or white gold) won’t last. My
questionis two-fold:
Is there any process that will permanently blacken silver or gold?
(I searched the archives but didn’t quite find an answer)
Will rhodioum plating damage mystic topaz and diamonds or should
Ihave it plated first and then set the stones?
Any help on either question is greatly appreciated!
Thanks,
joanne
Joanne- There are two issues here that I see.
A: Mystic topaz is just quartz with a very this surface treatment.
Quartz is not an appropriate stone for a wedding ring. It’s waaay to
soft for an every day ring. The “mystic” part will most likely die in
the plating process. The center quartz stone may last just few years
at most.
B: There is no really permanent surface treatment for silver or gold
that will withstand daily wedding ring wear.
If you look at our friend Sarah Graham’s lovely work, the black part
is a special alloy of steel that she has cast by Techform. Black
rhodium will NOT do. There are some powder coatings that are harder
and will last longer, but they still are just thin surface treatment
that will wear off eventually with every day wear on a ring.
Etienne Perret is doing some lovely work in ceramic in black as well
as other colors. Worth checking out his work.
Just make sure it lasts.
Jo Haemer
timothywgreen.com
