the angle of the burnisher does not completely limit the angle
you can get with it. You don’t just push the thing straight down.
I do understand this, though I really appreciate the effort of
describing the process (as others may as well). So far, I haven't
been able to get this to do much on faceted stones, but I will
revisit it. I really do need to make the process as "idiot-proof"
as possible, since I'll be doing it with beginners, in a hotel
conference room.
Noel, it’s probably also worth mentioning that using these can take
some strength. Unless the tube is very thin or soft, one often has to
push rather hard to get it to appreciably move metal.
One other trick in tube settings worth mentioning applies only to
smaller tubes where it can be still just a tube, when you set it,
rather than attached to something. This usually means you’re able to
set the tube, and THEN solder or weld or otherwise attach it to the
jewelry, and for this at it’s easiest, you need to be able to start
with a length of tube long enough so you can chuck the tube into your
#30 style (jacobs chuck) flex shaft handpiece. Alternatives would be
lathe chucks, drill press chucks (harder to do since you’re working
upside down), or the like. With the ability to spin the tube under
power, you can hold a suitable setting bur or other bur just in
pliers in the opening of the tube while spinning it (rest the tube’s
upper edge on a groove in the bench pin to be sure it spins true),
thus cutting the seat in a lathe cutting like operation. Put the
stone in, hold with a tiny bit of sticky wax if needed, and then,
with the tube spinning and braced against the bench pin, simply press
a burnisher, or prong pusher, or almost any other flat steel surface,
against the upper wall of the tube. You can burnish the thing right
over in seconds. Works great with diamonds especially, where you then
can take a small bullet point burnisher (made from an old burr, or
better, a small carbide one), and then burnish the inside bright edge
of the tube (still spinning). With the tube spinning, the result can
be not only a very quick setting, but super clean. You can even, if
you like, then finish by spinning the now burnished sharp clean edge
of the bezel against a millegrain tool for a perfect millegrain on
the edge (sometimes hard to get when hand millegraining a small
diamber tube setting…) I’ve used this method many times when I
needed a bunch of small stones in tubes where I could attach them
after setting. After it’s set, you can saw the desired length of the
tube with it’s set stone off, spin the new edge against a file to
clean and level it off, then repeat. If you mount a saw blade in your
saw frame with the teeth pointing up, then spinning the tube (if
held, as I do, in the left hand when I do this, so the side of the
tube facing you is spinning down), then you can saw off the tubes
quickly just by holding the saw blade against the spinning tube, to
get a nice level cut too. (cut a slit in a zip lock back, put the bag
over the tube, and hold the saw blade in the slit, so you’re cutting
the tube off inside the bag. keeps it from flying off to parts
unknown when it cuts through.
It’s a great way to set a bunch of small tubes when you need to do
one of those “diamonds by the yard” sort of chains, or otherwise need
lots of small tube sets. It’s limited mostly by the maximum size of
tube you can fit in your chuck, and soft stones will be hard to
burnish the inside edge without damage. And obviously, if you’re then
soldering the tubes to something, the stones need to survive that.
Laser welders, though, remove most limits in that regard…
Peter
