Hello everyone!
I am looking to buy a hydroflux water torch but I would like to do
more research on other people who have used it. Based on all the
reviews/threads I have seen on Orchid, everyone pretty much seems to
love it. Most of the reviews I have read seem to be geared toward
repairs a lot more than fabrication. i have not seen any videos
using this particular welder. I know that it cannot be used for
casting but my concern is will it be able to heat…let’s say, a box
ring? I contacted Rio Grande and they said that if my jewelry was as
big as…say a 2" navajo cuff bracelet (which I will most likely
never make), then the torch would not generate enough heat to melt
solder. When I called Otto Frei, I was told that if I heat a piece
bigger than a 50cent piece, i would have problems fabricating jewelry
since the metal does not get hot enough. is this true or is the
person just not using it the right way? for the jewelry pieces that i
make are not very large—mostly enameled pendants, rings and
earrings. Can you tell me some of things you have made using this
particular torch?What potential problems are there? I would really
appreciate it if you could shed some light on this issue. Thank you
and I am looking forward to hearing from you.
Dara
