Can I fuse small copper wire to a copper cuff how
You can solder wire,not sure if fusing would be possible.
I have fused copper before. It’s pretty ugly. If I wanted to join two piece of copper, I would use copper or silver solder. I do run a hot torch along the edge of a piece of thin copper sheet fusing it because I like the results from a design point of view and it will strengthen the overall piece if I want to bend it as in a cuff bracelet. Copper is pretty cheap. Buy some and give it a try. Be sure to use a lot of flux and a lot of heat. Good luck…Rob
Thank you let u know how it goes
I have used Rio’s copper solder. Sometimes it comes out a nice bright copper color match, and sometimes it comes out dark grey. I’m not sure why (perhaps temperature?) In either case, whether copper colored or grey, I prefer it to silver solder because it doesn’t stand out . I think the key whether using silver solder or copper solder is to have a tight joint and only use the amount of solder you need to minimize clean up the goal being to end up with a infinitesimal join. In retrospect, I don’t find it unacceptable to use silver solder on copper except in the case of copper chains where I see that repeating silver bit. In fairness, I haven’t tried plating chains to cover the solder join though I hear that is an option. I don’t do enough with copper chains to bother. I also recommend experimenting with fusing. It would be interesting to try it in a kiln.
Consider TIG welding or the use of a SilPhos type brazing rod. Many different types, some need no flux and flow in a lower range then silver solder and color is closer. These products are often used in refrigeration for joining copper to copper or brass fittings. Does a nice filet or v notch to join a plate. Welding supply or ebay or McMaster-Carr Larry
From one who has used many pounds of Rio’s copper solder, I suggest using it. No flux is needed with it. At really high temps, it does come out gray. Just contaminate your pickle with a bit of steel wool or any other steel. Let the piece sit in the pickle for at least 10 minutes if hot, and about 1/2 hour if the pickle is cool. The gray will be played over with copper.
Aggie, I plate the whole piece after soldering as well. So easy and gives a beautiful seamless look.
I am new and self taught. Because l am new and my work often does not look professional yet and because money is an issue, l work with bronze and copper often. Lately, l have been using gold solder on the bronze; certainly not the cheapest solution.
I was very intrigued by your comment about plating. How is it done?
