Specific tools/ heating tools??? Thanks in advance
there is a tool for making an edging on wedding bands called a miligrain tool… that would give a similar pattern to filigree wire(twisted wire pattern).
hello,
perhaps use a round wax bur to texture?
again, “edges” of textured depressions look softened
perhap soften with a flame…?
julie
Use an old bur or beading tool, grind the tip to a point then slightly round off the point. You can use it in a pneumatic handpiece or tap it manually with a hammer. Adjust the sharpened tip and the way it’s contacted until you get the desired texture.
Yea I’m sure It can be done post cast but I’m thinking it would save alot of time to do the pattern direct into the wax, I was thinking it might be some type heated dental tools or wax iron that was used to creat the effect
Yes I’m sure you could come up with a texture suitable.
