Consider moving to a more unpleasant climate in the interests of safety.
Jeff’s humor is to the point, but it’s not really that simple,
either. And as Jim Binnion said, these things are more about
maintenance than safety - well, a bit of both, likely.
I think that it’s important to remember that not everybody here has
an everyday attitude towards gas and torches. There are people
everyday buying their first torch… And though Jeff’s comments
were genuinely funny, I don’t think we should scoff at people’s need
for beginning knowlege about gas and torches.
It’s also important to understand that much of the info out there is
generic, and aimed at the welding industry as a whole, regardless of
large or small. So you have shops with 100 torches, one inch gas
lines, and liquid oxygen for the oxygen supply. Flames and plasma
everywhere… On the other hand, I have a gas barbeque, using a 5
gallon LPG tank, and the instructions say nothing whatever about
bleeding lines or disconnecting them.
“Turn it off when not in use.” That’s it, that’s all.
Jim’s writings about what happens inside a regulator were very
interesting - no doubt truthful and I’m sure good advise. I’ve never
had any troubles with my regulators, but that doesn’t mean that
somebody can’t, either.
There are some truths, though: The gas in your line would probably
just about fill up a drinking glass, in terms of safety. Take a
match to that glass and it would go “poof” and be done with. I filled
up my above-mentioned barbeque with gas because it didn’t light, and
then I lit it. It went whooooosh, lifted the lid a half-inch, and
that was it. No biggie, though I wouldn’t recommend it, either.
Everybody has gas lines in their house, everybody in urban areas has
gas mains running down their streets. 12" pipes, full of gas.
Somehow we all manage to sleep nights. And the key to that is
installation. If you= r fittings are quality and properly installed
and your hoses and connections are in order, you are done. As Leonid
said, gas lines don’t just wake up in the middle of the night and
decide to leak. Do it properly, don’t forget about it but don’t
dwell on it, either, and move on…
As has been mention several times, the biggest risk is in the
3000psi oxygen bottles. Miniature rockets, if given the chance…
