Honeycomb Block
Hello all, I recently bought a honeycomb block so I can better support
small items, and I am wondering if there is anything I need to know
about its use. What kind of pins or gadgets do you use to anchor
items in place? I usually use a charcoal block and I am wondering if
the honeycomb block takes a lot more heat to get the same results as
a charcoal block. Also, it looks pretty fragile - is it?
Any tips would be appreciated - thanks.
Sue in VA
What kind of pins or gadgets do you use to anchor items in place?
I cut “U” shapes from paper clips then burn off any plating on the wire
before using.
It seems the more you use it the more fragile it gets. Mine usually
last a year before I drop it or knock it off the bench to shatter
into a dozen pieces…
Rick Copeland
My honeycomb block holds up very well. It is not a substitute for
a carbon block but is a good heat reflector and work holding
surface. My work holding trick with these is : Take some nichrome
Kiln heating element wire about 1 and 1/2 inches long . bend L
shape pieces with one arm about 1/2 inch long or a little shorter.
Make the bend a little over 90 degrees. insert the short end in a
honey comb hole. The long arm makes a good clamp to hold work in
place. Use as many as you need – they last until lost. You can
also use stainless steel or titanium wire. Solder won’t stick to an
oxidized wire so , get them dirty with oxide.
jesse
Sue: My honeycomb block is my best soldering friend. I use T pins I
got from a fabric store. I have them in various sizes as the smaller
ones can slip into a half a hole when the bigger ones won’t. The one
thing I learned the hard way was to use white out on the pins before
soldering. They will end up soldered to your work.
Hope this is helpful.
Carla
