Hello, when annealing in a kiln silver, bronze and copper sheet, how long do I need to hold at the anneal time for each metal?
Thanks,
Deb
15 minutes for silver. I don’t know about the others.
Thanks!
Following is link to a Stuller resource that discusses annealing and hardening silver in a kiln. I often use my kiln to harden silver pieces at 600 degrees. I have also used it to anneal coils of wire, but it takes a long time to get to 1200 degrees, so I usually just use a torch. You should coat with some kind of flux first. I use alcohol and boric acid. The silver will likely come out with a discolored surface, but it polishes off readily…Rob
Thanks Rob, I need to anneal rolled sheet.
deb@gemrapture.ca
780-953-8234
Thanks for the link Rob. Silver is 1100F and hold for 10 mins followed by water quenching. Based on the article I am going to assume that 10 mins is the standard.
