I just finished setting some stones in a set of sterling silver
ear jackets and found out that the hole for the earring post is
to small. Is there an easy way to enlarge the hole. I do not,
and have never done any metal working.
silver ear jackets and found out that the hole for the earring
post is to small. Is there an easy way to enlarge the hole. <<
There are a number of ways to do this. Which way you select
depends on t he tools you have & your experience.
Enlarge the hole with an appropriately sized drill bit. The
drill bit can be mounted in a power tool or pin vise for drilling
manually.
Enlarge the hole with a tappered reamer. They’re available
from jewele rs suppliers in sets of 5 or 6 for about $12.00.
Twist a scibe or heavy needle in the hole until the correct
size is reached.
I’ve used all 3 techniques to enlarge holes at one time or
another, it ju st depends on the circumstances.
richard if you don’t have any jewelry tools then try a straight
pin in the hole and wallo it out some. if you want you could go
to the hardware store and purchase a drill bit a little larger
than the posts. or take the jackets to a jeweler and ask if
he/she could drill them for you. It would take 1 minute and the
probably would not charge you. hope this helps michael mathews
post is to small. Is there an easy way to enlarge the hole. I
do not, and have never done any metal working. Any help would be
greatly appreciated.
If you have a round needle file you could just file the hole a
bit to enlarge it . . . another option would be to drill a larger
hole.
