However, a design that cannot be completed unless soldering ~on~
the diamond takes place is one that should be revisited.
Somebody the other day asked about the hows and wherefores of
soldering diamonds. Hans’ comment above shows a common attitude,
here on Orchid - that there’s something scary, strange or dangerous
about doing it. In reality it’s an everyday occurrence - since
diamonds can take the heat of normal gold soldering, it’s a property
that is used to it’s best advantage in the diamond jewelry industry.
Yes, the pieces I showed ~could~ be done with out soldering. Most in
twice the time at half the quality. Since the stones can be soldered
on, you set the channel, polish everything up and just set it in
place - quick, clean and easy. Just like the “Casting VERSUS
Fabrication” thread - sure, you can fabricate it, but why would you?
I get the feeling that many folks are getting set up, lighting their
torches, tensing up their backs and tentatively going in. Then
saying, “Whew, made it!” when it works. If you use a boric
acid/alcohol dip, use normal soldering procedures and don’t get them
glowing orange there’s no reason you can’t solder on diamonds just
like you solder on gold. I’ve done it up to around 10 carats or
so…
There are caveats: They must be surgically clean. Neil wrote about a
burned pavilion today - I wonder if the stone was clean on top, but
not the bottom. If there is dirt or grease, it will burn and burn
into the stone. I (and Peter’s explanation) already mentioned that
stones can break from the contraction of metal, but if you have
channel setting and the stones are touching or overlapping, they can
chip each other in the same way. That’s pretty common, in fact, and
it’s something to really look out for.
I burned the point off a marquis as a youngster. I’ll lay out
baguettes on masking tape to do the work. Was a time I soldered on
some and they came out burned. I realized it was because I hadn’t
washed off the glue residue from the tape… Other than that I
have NEVER burned a diamond, and I’m not exaggerating when I say how
many I’ve soldered on. Chipping and such from the things in the
above paragraph - occasionally, yes.
It’s like (what should be a mantra in) polishing - “if there are
scratches it’s because you put them there.” If the diamond is too
hot, it’s because you made it so…
It’s just not a big deal…
