Orchid Digest Post:
Hand problemsFrom: etienne perret perret@hotmail.com
If you don’t have a bench mate tool, cal Quesswein or Rio today
and order the GRS bench tool set. It will change your hands
situation over night. You won’t know how you ever lived without
it. best wishes
Teresa: I don’t have experience with this myself, but awhile back
there was a thread on hand problems and several people
recommended working some time every day with silly putty, just
working it in your hand. You might try it. I would keep on with
my glucosamine and chonroitin, as I just read a book on the
arthritis cure, and the author thought the research on these was
persuasively positive.
HTH,
Roy
I too use to suffer from hand problems. What worked for me was
chinese massage, some accupunture and I started taking Yoga
classes. All of the above changed my life! It is really
important to strech out your hands and learn to relax your hands
when you are not working. When your hands start bothering you-
take a break. If you let it go on for too long it will start
affecting your neck and shoulders too.
Take care.
DeDe
Teresa, I agree with RnL regarding excercises for your hands and
the use of a dietary supplement called MSM
(METHYLSULFONYLMETHANE). Can be purchased at a good health food
store and they will have an info sheet on it. I take 750 mg a
day. It has totally gotten rid of shoulder pain where I was
told by my orthopedic that i had lost the cartlidge buffer
between my collar bone and shoulder (where the two meet is
called an AC joint) MSM seems to be a wonder “drug”. I learned
of it from a friend whos chiropractor recomended it to her for
back pain. She has had amazing results too. I even stopped
taking it for a month to test its results and the pain returned,
have been taking it for over a year , no side effects. Might be
worth a try. Gary in Redding, Ca.
theresa: your hand problems are right up my alley. i have 11
years experience as a hand therapist and i am also a jeweler. i
have developed a lecture series called “workspace design for
jewelers” that deals with your the physical challenges
experienced by bench jewelers. this talks about
modifying/adapting tools and the studio setting, bench aids,
exercise programs, treatment tips, pace and break schedule, etc.
if you want to e-mail me personally at healdoor@juno.com and
tell me some more of your specific challenges, i may be able to
give you suggestions targeted for your exact problems.
yours-marci lebowitz
Teresa:
I was thinking some more about your problem. On top of all the
other things I have mentioned in my last email that might help
you- you should make sure you are sitting properly while you are
working. Make sure that the bench is helping to support you
while using the flex shaft by supporting your elbow on the top
of the bench. In order to do this correctly you must be seated
properly. Lapidary Journal years ago had an article about
sitting properly at the bench. If you contact them you may get
a copy.
Make sure you have a good chair that provides proper support for
your lower back too. Your whole body is connected and I bet if
your hands are bothering you- may be having neck and back
problems too. I know it may not sound like much but last year my
hands were really scaring me and I started Yoga, Chinese massage,
bought a decent work chair and started sitting properly and all
my hand problems melted away.
Keep care!
DeDe
Although my problem is carpal tunnel related, I have found the
GRS Benchmate system to be a tremendous assistive device. I have
also wrapped the handle of my jeweler’s saw to make it easier to
manipulate with a lighter grip.
There is a local metals professor who is preparing an informal
guide to hand exercises which help to prevent repetitive motion
injury. I will be happy to share with his permission when it is
available.
I’ll be interested in additional suggestions, as well. I look
forward to bench work for many years to come. Pam
I have found that Handeze therapeutic gloves, while not
strengthening my hands, seem to keep them from getting tired and
sore. I see them as more of a preventative than a curative, and
would be interested if anyone has used them or has more knowledge
about the longterm benefits, if any, of using them. They are
available at most drugstores for approximately $20. Alana
Theresa,
My hands were severely damaged by Lyme arthritis. Glucosamine
and chondroitin work well. Peeling yucca leaves work well on any
type of rheumatoid arthritis, but it’s difficult to find a
supply. I get mine from private land when I visit New Mexico and
Oklahoma.
One thing I’ve found that helps is to build up grips on your
tool handles. Dense foam, such as the spongy material which is
used for insulating some mugs, taped on with electrical tape
works well and is fairly cheap. Actually, downright cheap if you
pick up the mugs at garage sales.
Another thing which I’ve found for more small files is a plastic
handle with an adjustable collet inside. I just use some tape on
the tangs of micro files to build them up so it can grip
securely. They’re about $3-$4 from Thunderbird Supply in Gallup,
NM. I think RGA has recently begun to sell them also, as well as
adjustable handles for larger files.
Also check into physical rehabilitation places. Often they have
equipment and/or catalogs filled with things for people which
have limited use of their hands due to trauma and illness, which
can be adapted to jewelry making. KP in Wyoming
