After casting using various centrifugal casting machines for 30
years I have begun to occasionally also use a vacuum casting machine
and Kerr Electromelt furnace to cast.
My questions for the group are about the graphite crucibles for the
hand furnace. I like the graphite because it seems to absorb gases,
giving me few to no micro pits…I really like that. But after I use
the crucible for 5-7 pours, the hard surface of the graphite begins
to break down. Even if I carefully vacuum it before the melt I can
get annoying little bits of graphite in the casting. Coating the
crucible doesn’t seem to help as the flux just collects at the
bottom. Also judging when the crucible has reached the end of it’s
useful life is a little tricky, meaning I really want to avoid
having the bottom of the crucible drop out during a melt.
So how do you deal with the degrading crucible and avoid graphite
pits? And how do you judge when the crucibles wall are getting too
thin?
A somewhat unrelated observation about comparing centrifugal vs
vacuum casting is that I have noticed that the vacuum castings seem
a bit softer. I say that because if I cast 14K white, one spun and
another vacuumed, and thenput the two castings in a magnetic
tumbler, the casting that was vacuum cast if more noticeably dented
than the one that was cast in a centrifuge. Not a problem, just
interesting.
Thanks,
Mark
