Hi Ginger,
I can’t remember who’s teaching at Miami in the main program, but my
memory is that there is still a real program. You might ask
whoever’s there where they get their blades sharpened.
First and best option is simply to pull both blades out of the
frame, and take them to a tool & cutter grinder. They’re a company
that resharpens industrial tools. There’s got to be one down in
Dayton, and I know there were several in Columbus when I lived
there. That’s what they do for a living, and they’ve got the gear to
do it right. Probably about $50 or so. (Look for industrial drill
bit and end mill resharpening services. )
You might also call local printing companies, and ask them who
resharpens the blades for their paper cutters. Same guys, same gear.
They probably won’t know it’s the same sort of deal, but if you
show them the blades, they’ll figure it out. (Industrial paper
cutters go through a couple of blade sets a year, while metal shears
go years between regrinds, if they ever get reground at all, so
they’re not as familiar with them.)
The guy in the next industrial bay over from Knew Concepts is a
cutter guy, and he does outstanding work, if you feel any real
urge to ship your blades to California. (Seems silly to ship them
all that way, but if you want to, contact me directly.)
Getting the blades back in and shimmed correctly will be fun, but it
shouldn’t be too hard.
Next option would be to pull the blades, and very carefully touch
them up on a belt sander. Make sure you copy the angle of the
short side (edge) of the blade, and only grind the edge of the
blade, not the faces. The edge is the thin side that forms the
thickness of the blade. It’ll be tilted down at an angle. (Probably
somewhere around 5 degrees.) That angle’s important, so make sure
you set the belt sander’s table to match it. Do NOT try to
hand-hold this. Set the table, and use it as a guide to make sure
the angle stays even. Take a grinding pass, then dunk the blade in
water. Rinse, repeat. The goal is to never let the blade get hotter
than what’s comfortable in your bare hands. If it gets overheated,
it’s ruined. (overheated too hot to hold, or if you see any hint of
rainbow colors.) (It’ll be way too hot to hold before the rainbow
colors show up, but if they do, you’re cooked.)
If it’s a guillotine shear, it’s important that you take one smooth,
continuous pass across the blade, so that the top stays straight,
with no nicks or dents. If it’s a plate shear that has curved
blades, just remember to echo the curve that’s already there, and
don’t leave nicks. For something like this, I’d probably use a 120
grit belt. A worn 120 if there’s not much to come off. Make sure
it’s grinding well before you risk your blades on it. Practice on
scrap first.
If you’ve done it (or seen it done) once or twice, it’s not hard,
but that first time can be a real ‘learning experience’ if you’re
winging it.
For whatever that was worth,
Regards,
Brian
