Hello everyone!
I am faced with another dillema… so I come to you for help… again.
I have a request to make a ring in 18k gold that would have a gray-ish white color. I have 999.5 Pt and 999.9 Gold available, along with fine silver and copper. Is there a formula that would yield the desired color and still allow me to hallmark it 18k gold?
I could just order Pd master alloy, but I like to mess things up, usually, so I couldn’t skip this opportunity
As someone who is constantly developing gold formula’s myself, I will be watching this post closely. I would recommend using palladium, not platinum and alloying it with 75% gold, 16% palladium and balance silver. For platinum you might want just gold and platinum, 75% gold, 25% platinum.
Hello you can use palladium and silver to alloy 18k
I use it ad it gives me good results in terms of color ad malleability, just do not use acetylene or graphite for melting or stirring 75 Au, 18 Pd ,7 Ag.
Thanks! Unfortunately I don’t know of any source for pure Pd here in Europe, while Pt I can buy in small (1g or 5g) ingots.
I try to find a way to use what is at hand
For Pd white gold, I could buy the master alloy to mix with gold, but I would rather develop my own mix, as I can consistently repeat it and not depend on any individual producer.
I looked it into it, platinum doesn’t act as strong as palladium as a whitener and makes the gold more dense. Plus an higher melting point would make it quite to become homogeneous.
Hi, this is a company in Belgium where you can buy palladium, hope this helps you, https://www.argentorshop.be/en/jewelers
I can give you probably also adresses in Germany
Greet
Thank you for the link! Hey have it and deliver to my country :). I’ll order a 5g plate and start from there.
If you could one day find the address of the Germany shop as well, it would be helpful to have more than one source
