Gold pen plating on sterling and fine silver
Another puzzler for me:
I keep seeing instructions from plating suppliers that indicate the
proper way to plate Gold onto Sterling and/or Fine Silver is to first
lay down a layer of Nickel to avoid the “naturally occurring bleed-
through of the Copper in the Sterling which will happen over time”. I
find that keep experiencing some revulsion at the idea of
intentionally putting Nickel on Sterling, even if the final result is
’good looking, long lasting Gold’. Is this just a marketing ploy to
sell more product, or is this really something I should consider?
Can Gold be pen-plated onto Sterling and Fine Silver (hopefully, in a
way that highlights, rather than overwhelms the piece) without risk
of a later Copper bleed-through result? I’m actually thinking of
using a rose gold (cyanide based) for this - applying on Fine Silver
flower petals and Sterling Silver flower pistil. I know that the
rose gold solution has a higher content of Copper already in it; is
this detrimental without the Nickel layer? Should I consider a
different approach? Is plating without the Nickel layer feasible?
Charlie
lay down a layer of Nickel to avoid the "naturally occurring
bleed- through of the Copper in the Sterling which will happen over
time"
Dunno about the copper in sterling, but gold plate over solid copper
is a no-no. Over not too long, the gold will diffuse into the
copper. Nickel is the usual barrier metal.
Al Balmer
Sun City, AZ
Is this just a marketing ploy to sell more product, or is this
It’s not a marketing ploy. but it is slightly incorrect. The problem
isn’t so much copper bleeding through, it’s silver, as well as the
gold itself diffusing down into the silver. Gold and silver are
completely intersoluable in each other, and a gold plate directly on
silver, whether sterling or fine silver doesn’t matter, will both
tarnish over time, as silver bleeds through to the top and can react
with the atmosphere, but worse, the thin gold layer diffuses down
into the silver itself, and the color gets paler and paler. In a few
years, it won’t look gold plated any more at all. The nickel
underplate isolates the gold from the silver, and stops this
diffusion of each into the other.
It is possible to avoid the need to use the underplate if the gold
plated layer is exceptionally thick. That will cost you more. It
normally takes more sophisticated plating equipment to do a good job
of such a thick gold layer with a still good finish, and the added
needed amount of gold is a lot more costly than nickel. But if the
gold is thick enough, the silver won’t make it through to the top,
and the gold won’t disappear down into the silver. A simple example
of that is in Keum bo, where thin foil is adhered to the silver.
That gold foil is thick enough for the color to remain permanent, and
it’s about the thickness you’d need to get with plating for similar
permanence. That’s many times thicker than the usual gold
electroplate.
in a way that highlights, rather than overwhelms the piece) without
risk of a later Copper bleed-through result?
Sure. Use a nickel underplate with another pen first, just where
you’ll put the gold, and then gold plate over that (be sure to rinse
between metals, so as not to mix the nickle and gold, either on the
piece or on pens. Nickel is acid based, your gold, if cyanide based,
would react badly to that… You could try to get a super thick gold
plating directly, but pen platers are not likely to give you a good
enough thickness for permanence. But then, permanence can be a
relative value. How long do you want the plating to last? A year or
two? Then the pen plated layer is likely OK, especially if you take
the time to get it a bit thicker than just enough to color. But if
you want a decade out of it, then the first part of this paragraph
applies.
Peter Rowe
Thank you, Al and Peter, for clarifying this for me! I really
appreciate it!
BTW, Re: my other question about the annealing temperature for Fine
silver and how to recognize when it’s reached optimum conditions
(when 572 degrees F has been reached) - I did hear offline from Neil
A. who kindly reminded me about the 'black marker technique’
discusses in Orchid posts last month. That’s when I realized a
different “torchless” "way, which might be useful, would be to use a
digitally controlled kiln kept on hold at the proper temperature.
Can anybody verify the optimum annealing temperatures for Both Fine
and Sterling silver? Is there a source to go to for a table of
various annealing temps of various metals?
Thanks again to all Orchidians for the incredible insight you
continue to share! You are truly a treasure!
Kind regards,
Charlie
the proper way to plate Gold onto Sterling
Charlie, we do this both ways… with nickel and without. The nickel
is beneficial I think but we have never had any complaints either
way. We have a long time customer that has us do a lot of celtic
designs. He likes us to pen plate portions of the weave so it looks
more woven. He always asks us “not” to do the nickel… not sure why,
we have never discussed it. Hope this helps.
Dan.
http://www.classwax.com
