Just got the new Lapidary Journal today and there is a brooch of
fine silver with gold burnished onto it. How does one do that?
Dave
www.opendoor.com/stephensdesign/crystalguy.html
Crystalguy Art Jewelry, Magical Art Jewelry for the Enlightened Mind
Hi Dave. I was curious about that as well. My teacher told me
it was the Kumboo method (described very well in McCreight’s
Metal Technic book). Basically, base piece is heated over low
heat (say on an electric stove top or hot plate). 24K gold foil
is cut into shape desired and applied to piece with a wet brush.
Piece is heated more, then gold is burnished onto piece with a
burnisher. Just bought the gold foil at Metalifferous but
haven’t tried it yet. Take a look at the book chapter though
for the exact details.
Enjoy, rd
My teacher told me it was the Kumboo method (described very well
in McCreight’s Metal Technic book).
Thanks RD, I do have that book and will check it out…Dave
Hi Dave,
this is a Korean techique called Kum Boo(sp) and is very easy to
do.It uses 24K foil or slightly heavier if you are rolling down
your own. It is done on fine silver or sterling that has a fine
silver coat. The silver is heated on the coil of a hot plate or
by torch but not hot enough to change color.it must be very
clean as if you were going to enamel. The foil is laid in place
and burnished with a burnisher. It will easily fuse in place.
This is the simple version but there isn’t a lot more to it than
this. Wire brush with soap and water, do not buff.
Marilyn Smith
Thank you for asking that question, I’ve often wondered about
that process . . .
see the article on Keum-boo on the tips page Charles
Brain Press
Box 1624, Ste M, Calgary, Alberta, T2P 2L7, Canada
Tel: 403-263-3955 Fax: 403-283-9053 Email: @Charles_Lewton-Brain
Metals info download web site: Learning Center - Ganoksin Jewelry Making Community
Product descriptions: http://www.ganoksin.com/kosana/brain/brain.htm
Links list hosted at the Metal Web News:
http://tbr.state.tn.us/~wgray/jewelry/jewelry-link.html
